ABS AND BAS-ASR light on dashboard
Kelly1983
New Registration
Bristol
2.3 clk kompressor. S reg.
Hello everyone, the abs and BAS/asl light is on in the dashboard, most of the time they stay on with no trouble, but when they turn off it feels funny with the breaking and it will turn back on. I have a ASR switch which does not turn that light off. Obviously something ain't right, I have a mot on Friday and don't want to be conned into anything :), if anyone has any advice il be very great full, if not thank you 4 looking. :confused:
As the ABS lamp is on, the fault will be with a wheel sensor hopefully, the BAS and ASR need the ABS to be working, as they use it, so it should only be a ABS fault.
A STAR check with an indie will be the quickest way to go, to save searching around
