ABS / BAS WARING LIGHT COMING ON ?
HERBIEMERCMAN
PRESTON, LANCS.
97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
Hi Everybody, I have recently started to get the ASR / BAS warning lights coming on, i follow the procedure for clearing all faults by switching on the ignition and then going through all the gear settings, this clears the problem. Does anyone know what can cause this problem? as everything seems to be working ok. Herbie.
BillyBoy
W213 E400d All Terrain
You get these when you disconnect the battery, so could it be a sign your battery is in the way out? Other than that, could be a sensor, but would need to go in STAR to diagnose any faults.
mioba
Nottingham and Köln
most likely a abs/speed sensor.
Star will tell you the fault.
get genuine merc sensors ortherwise you will be replacing it within a couple of years as opoposed to every 15 years.
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
Thanks guys i will get my local "Inde" to put it on "Star". Herbie.
www.ckinsurance.co.uk
