Abs esp inoperative
John diffley
204 250cdi
Hi have this problem abs esp inoperative also have mesage run flat indicator inoperative, cruse. Control not working and stop start not working this is 204 250cdi 2011 model thanks in advance
John
Sounds like a bad ABS sensor. You'll need to get it on a diagnostic machine to identify which.
Or brake stop switch which would be good news as they are £12
Ah yes - good point though will that kill TPMS?
OP - the brake switch is a double switch so looking at your brake lights may not show an issue with it as its the other circuit that can fail).
I don't have tpms , but it did stop tyre monitoring on mine (via the abs/tyre rotation system ?)
J
John diffley
204 250cdi
Thanks boys and girls for your suggestions, it was the front abs sensor n/s did an ohms test just to make sure.all fine now.
John
