abs light on 316 sprinter van
sprinter316
wakefield
sprinter316, e300 diesel
Ive had my bottom ball joints replaced and new pads at the same time. now i have abs light on, traction control light on, and also esp light on.....
please can any one help.
The van is a merc 316cdi 53 plate. now due for test and want pass with these faults. please help :-(
They have not fitted the speed sensors correctly
sprinter316
sprinter316
wakefield
thanks, i have asked and they did not remove any sensors. removed hub in one piece, to the side. thanks again
any more ideas.
You cant remove the hub without removing the sensors
sprinter316
sprinter316
wakefield
sorry malcom, the mechanic told me he moved the hub to the side and did not disconnect any wires. i dont know if he trying to pull the wool over my eyes, thats why i am using this web page, can you please advise what he should have done so i can confront him, i am having it on a electronic machine in the morning to see which if any are damaged, thanks again........
It only takes one to dislodge and thats it, you always unplug them first to avoid damage, so there we go
sprinter316
sprinter316
wakefield
sprinter316
thanks malcom, your advice was spot on thanks, speed sensor not fitted correctly......... thanks again.......
Good luck and thanks for posting back :D:D
