ABS Light
Paul1948
Bournemouth
S320 CDI 2003
My W220 s class has ABS light showing using iCarsoft unable to cancel error or show a fault. This occurred after battery change. can anyone help.
many thanks Paul
Can you check the live data on iCarsoft and see if one of the wheels is giving an erroneous reading.
P
Paul1948
Bournemouth
S320 CDI 2003
The code given is C1540-008, but iCARSOFT does not have the translation
Taffy7hfa
Oxford
As the battery has been removed you may need to re- calibrate the steering wheel angle sensor by turning the wheels from lock to lock a couple of times.
tpn
S204 OM651 2012, Daimler V8 250 X 3
This is a steering angle problem, often brought about on start up by a low/failing battery.
Icarsoft has a function whereby you can reset the steering angle. Make sure you are in a large area where you can turn left and right without stopping. The instructions will appear on the screen, as you drive.
P
Paul1948
Bournemouth
S320 CDI 2003
Thanks for the info, will try tomorrow, will let you know the results.
P
Paul1948
Bournemouth
S320 CDI 2003
Hi all,
so far no success, but maybe closer to the problem, readout showed the problem as B24/15, Rotary speed and lateral acceleration sensor now I need to find the Mercedes number . Thanks for the help.
tpn
That usually brings on the ESP light. Is it on?. Low battery can bring on these faults. You say you changed the battery. Is the new battery ok? Also the steering angle sensor being faulty or not reset can bring up other faults, as the yaw rate is inextricably linked via the ABS.
P
Paul1948
Bournemouth
S320 CDI 2003
Mercedes said the sensor rate A0025426618 was causing the problem, their cost £643 plus £300 LABOUR PLUS vat, was replaced with a known working one, with no change so I need to investigate further. Cost of secondhand spare approx £ 10
any further help from anyone....thanks Paul/
