Abs sensor or ring ?
cls320cd1
2008 cls 320 cdi
I have a 2008 cls 320cdi.
Abs fault,
Diag had no reading from front right, I check sensor and replaced and that's good, now front left is intermittent, its says check distance from sensor, could this just be a sensor or do they have abs ring
mersum1es
Finland
of course they have a ring, laminated to rubber ring. 90% its ring fault, not sensor. Also bearing gap may cause misreadings.
C
cls320cd1
2008 cls 320 cdi
What I was leading to was, do they have a ring or is it built into the bearing.
I haven't taken that side apart yet, that's my next challenge. Are the rings visible without taking hub apart.?
ajlsl600
france
You might see enuf if u remove wss and shine torch down hole. I may get lucky and be able to blow any crud out with compressor and long nozzle blower failing that it's take to bits, vissualy inspect change as required
C
cls320cd1
2008 cls 320 cdi
I took caliper off to gain access, gave it a clean and it was still intermittent so , I though **** or bust, I gave the ring a good scrape with screwdriver and the way around, and now no signal at all. So new ring needed I think.
Trying to work out if I can just change ring or if I have to replace bearing too
ajlsl600
france
Take a look at an online pts list ecp foe eg I think you can just change ting, but check or call dealer pts dept
C
cls320cd1
2008 cls 320 cdi
OK, I bought a new bearing, with new abs ring/oil seal.
I've fitted the ring and run live date and it reads it lovely.
I'm just a little cautious of the hub nut now, not sure how tight to do it before slacking off and how much to slacking off, I guess I'll have to wing it lol
C
cls320cd1
2008 cls 320 cdi
More news, abs is good, and power steering works well, especially is still coming up, and I have one more fault, brake lamp switch, but brake lights work.
C
cls320cd1
2008 cls 320 cdi
All done. Fitted new switch to brake pedal and cleared faults.
No lights on dash and drive perfect.
Passed mot today too
