My thoughts on sealant additive would be NOOOOOOOO !!! . I would think taking it to a reutable aircon engineer or Steve at Avatgarde near Bristol woul be your best bet initially .Just returned from a happy time in drop-top mode in France and then N. Wales (Zipline Birthday present from those in the family who may want to inherit...!) and sad to say the air con. seems to be underperforming.
It is certainly less effective than it was after a re-gas (on acquisition) last summer.
There is some (but not much) cool air from the vents, but (even in Snowdonia last week!!) not enough to cool the car when 'mugginess' overcomes the wish to remain 'topless'.
So I have booked in for a system check-over and have been told about a sealant additive to eliminate any 'minor' leaks.
Any thoughts on/experience of sealant used in the Air Con system please?
Aha!'Aye. There's the rub!'
Don't know if there is a leak.
But the process of elimination (Bought the car last year. Air Con weak. Re-gass cured the problem and here we go again...)indicates that's the likely problem.
On return back to MB who pressure tested no leaks and topped up the gas again
They couldn’t explain why the refrigerant had almost all gone but said they do lose a bit here and there in operation
I will be monitoring.... don’t fancy AC service every 9 months
Remember that you do need to use a/c all the time , or the seals dry out and let the pressure down . (Just seen that you were thinking along the same lines !)Many thanks for your prompt reply. It echoes my thoughts (hence the missive) but...
The recommender in this instance is not of 'The Hole In The Wall Gang' fraternity. The (Indy but not Merc) garage (15 years in biz. with sound reputation and a 'specialist' (at least, self confessed) in Air Con.) has repaired (by re-charging the Air Con. on) a previous SLK 171 for me some years ago, with a successful outcome.
Like you, I'm not a fan (tee hee) of Rad Weld and the like, but the days of stuffing a pair of tights into the oil filler to reduce the engine's death rattle prior to sale are, one hopes, behind us.
So maybe, I wondered, the marvels of modern science could have conjured a recipe which would stop a leak without clogging up the whole works.
Maybe?!
Aha!
I ask as mine was similar
Service and regassed last July by MB who said they leak tested and no issues.
Early May this year with our first hot weather and wife and I are in the Lake District ac non existent
Totally agree Gordon, twice the dye has gone in allegedly and twice no leak. There have been a spate of condenser problems with these too...On my SL they took several weeks to diagnose the leak. It was a crack in a pipe that flexed now and again ..not all the time , when being driven ... ..that pipe eventually replaced under warranty.
It was only found when they put the dye in the system ... I don’t believe e there isn’t a leak here ... an annual regas is totally OTT.
Aye! Working ok for the moment though so fingers crossed!Blooming frustrating though ..especially at this time of year...
as title- anyone on here run their climate control or AC at the same time as having the windows/Sunroof/Panoramic roof open?
I did with the SL in the winter but that was hot climate setting to get the body toasty on sunny days whilst still getting the roof down...
Debate:
