ADS 1 (think) 1990 500sl r129
roblloyd
R129 1990 500SL
CAN ANYONE THE ME WERE FAULT CODE NUMBER 6 is on the car and the right name, MB do not know got the past 4.30 and was told everyone gone home.
Adaptive Damping System (ADS)
Models Model Years
129.061 129.066 129.067 129.076 1991-1995
140.032 140.042 140.051 140.057 140.070 140.076 140.134 1991-1994
FAULT CODE TABLE
DTC Readout Possible Cause of Faults
1 No fault found
2 Adaptive damping system control module
3 Body acceleration sensor
4 Wheel acceleration sensor
5 Steering angle sensor
6 Front axle solenoid valves 1
7 Front axle solenoid valves 2
8 Rear axle solenoid valves 1
9 Rear axle solenoid valves 2
12 Right front axle vehicle speed signal
or
ABS Signal
13 Oil level switch (ADS)
14 Steering angle sensor not activated/initialized
15 Comfort or sport switch (ADS) short circuit
17 Vehicle load sensor
18 Adaptive damping system warning lamp
19 Volts supply too low
20 Steering angle sensor
21 Volts supply too high
22 Comfort or sport switch (ADS)
Rob
I have sent you a list that show where every thing is
Hi, is there any chance you could send me that list, it would be helpful...Keith
You do realise Malcolm (Television) passed away August last year...?
These are what I found in his files.
  • 129 ads complete.pdf
  • 129 ads layout.pdf
  • 129 ads axle vakves.pdf
Keith R129
1991 500SL r129
Models Model Years
FAULT CODE TABLE
1 No fault found
or
ABS Signal
Rob
Thank you very much. Now my only problem is to find out why I can't get any reading on pin 9 when I use my diagnostic meter. All other pins work fine.
