again gear loss
hopeful
clk cdi2.7 auto coupe 2005
hi little help in the sussing this fault , 2002 c220 cdi w203, last year was very cold has esi and battery ,gear faults ,charged battery larger than normal size so plenty power , the car eventually settled and all was fine till 3/4 months ago eis checked ,new key and link ,by pass or whatever it is called put in on steering lock, all well and driving great , till todays loss of gears . now usually in this situation key would not turn but because of afore mentioned bypass the car key will start the engine , but only had 1 st and reverse . aa out and read out wsa this,
attend to loss of gears, found stuck in 1st, rac scanned and multiple tcm faults. suspect ecu fault. clearedcodes and followed to members place of repair. member was hit while awaiting.
RAC DIAGNOSTIC SYSTEMSystem Type: ENGINE SYSTEM TEST/VALUESName: 611.962 - CDI 2DTC: P1664,Electric auxiliary heaterDTC: P2201,No or incorrect CAN message from EIS control moduleDTC: P2200,Instrument clusterSystem Type: GEARBOXName: GEAR SELECTOR - GEAR SELECTOR (EWM203) - AT - -> 2003/08DTC: P2001,The stop lamp status from control unit EIS over CAN; not availableSystem Type: GEARBOXName: GEARBOX - GEARBOX (EGS52)DTC: P2314,CAN; communication with control unit EIS is faultyDTC: P2316,Fault in Can communication with control unit air conditioningDTC: P2315,CAN: communication fault with IC (Instrument Cluster)DTC: P2600,Terminal 87; undervoltageDTC: P2602,Voltage supply of the valvesDTC: P2001,Fault stored in ETC (Engine Transmission Control)System Type: BRAKESName: ELECTRONIC STABILITY PROGRAM - ELECTRONIC STABILITY PROGRAM (ESPMK25)DTC: C1029,CAN; communication with control unit EIS is faultyDTC: C1174,Steering angle sensor not initializedDTC: C1210,+30 voltage, below lower thresholdSystem Type: CENTRAL ELECTRONIC UNITName: UPPER CONTROL PANEL - UPPER CONTROL PANEL (OBF203) - MT/AT
DTC: 9021,CAN: communication fault with IC (Instrument Cluster)System Type: CENTRAL ELECTRONIC UNITName: SIGNAL ACQUISITION AND CONTROL MODULE - REAR - SIGNAL ACQUISITION ANDCONTROL MODULE - REAR (SAMH203) - MT/AT - -> 2003/08DTC: B1089,Fault in CAN communication with control unit Instrument cluster. If fault code occurs with nocomplaint reported and no malfunctions, erase fault memory and perform a function checkDTC: B1094,Fault in CAN communication with control unit Right front door. If fault code occurs with nocomplaint reported and no malfunctions, erase fault memory and perform a function checkDTC: B1091,Fault in CAN communication with control unit AAC pushbutton. If fault code occurs with nocomplaint reported and no malfunctions, erase fault memory and perform a function check.DTC: B1057,Left luggage space light; short circuit
basically eis and gearbox ecu losing communication ,so cleared fault and is fine (below are the codes that are of concern) / i cant make up my mind ifthe voltage is low , not on the main battery ,but the auxillary battery ( location of said and how to check unknown, help please ) or its the ecu in the box !? , is this not in the plate valve body any input greatfully recieved . please note the car has been and has always been services box 40k and engine 10k and regular check s ,now edging 240 k
hopeful
hopeful
  • #2
can any of this be down to auxillary battery , if so where is the location
Botus
S500/2010/500
gearbox electroplate failing likely gets you all this fun - although it does appear if the battery voltage is high it copes less badly and it can seem to get over itself... (I guess at startup it throws teddies)
hopeful
hopeful
well all start and drive fine ,wont kick out of gear for ages then pop, we had this one day last winter start up and no drive except low drove a few miles ,came back on line intermittent reset , charged the rather over size battery and has been fine til now .i did think as it all started fine , could the aux batteriy be low (where is it ?)
ajlsl600
france
Try std batt. I had a nu of dramas after putting over specc batt on my w208 incl blown maf also has oil got in trans harness up to trans ecm? I think in ps footwell? That causes, all sorts of dramas.
After that I think fd electroplate, a possibility.
hopeful
hopeful
thanks for the input , as it is the same time of year as last malfunction ,and undervoltage i swapped batteries , and reinstated the emulater on the eis lock, so at least i could start the car and turn the steering, as it was due for a box oil change i decided to check out the tcm and electoplug on the box , (stands back and swears) yep oil the plug wicked oil and luckily tcm did not get completely soaked .any how cleaned out i/2 litre of oil ,replace the gearbox plug seals cleaned the loom and checked gear lever and connections on eis .cleared the faults , some history failed but thats empty aircon and heater relay run on ,not important. any how three weeks later still on the button running sweet easier start up and 52 mpg plus and not effected by the cold snap , it all seemed to star with the key not turning in the eis . hope this little episode helps some members, regards to all have a good christmas
ajlsl600
france
Frankly seeing oil attcm plug on my w208 want nail in. Coffin for me and w208. Otherwise by far best car I had all newer stuff is just dtf and empty ur wallet. Grand ur sorted
hopeful
hopeful
yeah disappointed with newer cars, research tells me to stay away at least till 13,cant believe the fault issues ,now there is multi link rear end and it does not seem a straight for do either, may get me a classic ?! . still got my 270clk sitting on the drive rotting , needs a box all new chassis tyres etc ,find a decent one and strip mine . garage thinks its christmas all year haha
Botus
S500/2010/500
not sure I get the stay away message -
all brands of cars have followed the mercedes development since 1995, with design to fail - its gone through phases - where merc damaged its reputation with the 220 and had to wind back the time to death across the board - then had a better idea and joined forces with the USA and cross pollinated the genetic illness to many other brands - whilst locally the Germans all loved it - with BM, VAG and Merc now only peddling a 3 year cycle to the trash can
the only one's that aren't utter criminals is toyota - with Mazda and Honda trying hard to stay afloat vs business models that is just marketing crap to fools
DSK
CLS 320 CDI, S350 Bluetec
Yep, MB, VAG, BMW is the most common stuff on the road and even on used adverts by some margin!
As the business circles say, you can sell anything to idiots.
ajlsl600
france
Not 2x tho.
KokoJB
ML320 W163
Hi; can someone help me please about the fault code that I have on my ML320 W163 year 2002? Fault code is P2600 Circuit voltage supply 87 has undervoltage; many thanks for your help.
malcolm E53 AMG
This might help - read the whole thread:
KokoJB
ML320 W163
Many thanks for the help; will do
And the other problem that I have is with the drive selector; I have on the Scanner the fault code P240C N15/5 The gear box don’t change over 1st gear.
