Air Filter Housing Wobble
camerontyler
Near Lockerbie
C 220 CDI 51 Plate
Good Evening All,
The Mrs picked me up from work the other day.
When she pulled up I thought the 'diesel rattle' was a bit louder than usual.
I lifted the bonnet and noticed the air filter housing heat shield was slightly touching a peice of metal below causing a metal on metal rattle.
I took apart the air filter cover and made sure that was all fitted correctly, which it was.
I noticed that the actual housing seems to have a centimetre or two of play and sits in a lower position rather than an upper position if that makes sence?
Due to the fact that i'm not the best at describing things in the engine bay I made a little video on my phone which i've uploaded to youtube.
Ideally I would like to know how to hold the filter housing in the 'upper position' i mentioned before as this will stop the metal touching.
I didn't record with the engine running so you won't hear the rattle but if you would like me to do a recording with the sound let me know.
Any help would be much appreciated.
Regards
Cameron
http://www.youtube.com/v/5gmswt1Zw48
On the inside of the box is two male torx bolts which have rubber mounts, i suspect you havent got the washers on the inside which as the bolts tighten, they push into the mounts and clamp it all tight!!
whitenemesis
CLS55 AMG '05
Mine wobbles a little too. Not as much as that though. Should there be any movement between airbox and engine?
Its rubber mounted so will move a bit but not like the OP,s....
C
camerontyler
Near Lockerbie
C 220 CDI 51 Plate
Hi, thanks for the swift reply.
Why do I get the feeling it's going to be a royal pain to get into the washer?!
I have my Haynes but it doesn't appear to have any info on getting into this area, any help would be much appreciated.
Regards
Cameron
Are you sure it isn't the rubber mounts on the top of the air filter housing? I mine were stretched so I bought some new ones from MB and the rattle has gone.
Ive had the same thing, mine had snapped.
Them two little rubber "straps" dont stop the up and down movement the OP has.....
C
camerontyler
Near Lockerbie
C 220 CDI 51 Plate
any chance you could take a photo of the rubbers you mean?
Cameron
