Answers FArom The Oil Expert Part # 2
Arzaam
Pakistan
W203 2002 c180
How often should the rear differential oil be changed on my car? 2002 w203 c180 done 87000miles
Is there a need to Change it? And which oil should be used
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #82
The coolant should be fine with the water top up.
I'd use a 75w-90 GL5 oil in the diff, or a 80w-90 GL5 if you can't get a 75w-90.
Cheers
Tim
Joesoap
Essex
W210 E220 CDI 2002
Hi Oilman,
Ive got 4 litres of TORCO SGO 75-140 synthetic gear oil is this ok to use in my ML270 diff? and does the transfer box take the same ATF as the autobox? i,e 236.14?
Joe
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #84
Hi Joe
Sorry, but I don't deal with Torco, so can't comment on their products. Yes, you can use 236.14 for both the autobox and transfer box.
Cheers
Tim
daytonabridge
Newcastle
2006 E280 cdi Sport
Hi Tim , I have just bought a 2006 E280 cdi Sport and as I didn't know when the last time the ATF was changed I got my local German car specialist to change transmission oil and filter . I'm not convinced they have done it right , can you tell me the correct procedure for the re-fill please , Ta .
Graham .
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #86
Hi Graham,
I am afraid I do not know the procedure, just the fluids that go in there :)
Cheers
Tim
daytonabridge
Newcastle
2006 E280 cdi Sport
Hi , does anyone know the correct procedure for re-filling transmission fluid please , thanks ,
Graham .
Arzaam
Pakistan
W203 2002 c180
Cheers
Tim
thanks, is it necessary to use fully synthetic gl5 or can mineral gl5 be also used without loss in performance?
mks2005
Estepona, Spain
1997 C230
Hi
hope you can help.
What kind of gearbox oil would my car need ? also how much would it need?
Its a 1995 s500 c140.
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #90
Hi
Do you know if it has a 722.3xx (4 speed) or 722.6xx (5 speed) gearbox?
Cheers
Tim
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #92
Daleaholic
Rochdale, United Kingdom
Mercedes E220 CDI 2000 & VW Passat 2.0TDI 2008
Please can someone advise the Mercedes oil code and best oil for my engine?
Datacard
Identification number: WDB2100062B193008 6
Chassis
Sales designation: E 220 CDI
Delivery date: 28 07 2000
Engine no.: 611961 30 259910
Transmission: 716640 11 085890
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #97
Hi
You need an oil that meets the Mercedes 229.1, 229.3, 229.31, 229.5 or 229.51 specification.
http://www.opieoils.co.uk/c-716-mercedes-engine-oil.aspx
If it doesn't burn much oil, any of the oils that meet those specs are fine, but if it does burn oil, go for one of the 5w-40s.
Cheers
Tim
A.J.
Norwich. UK
Only just read the 'Threadstarters' article, what a brilliant and informative article, well laid out and so easy to read. I didn't catch the the article when it was originally posted as it was before my time on this forum. It certainly aids the understanding of lubricants and highlights the naivety of using additives, not that I have ever considered it, even less so know. Excellent. :):):)
charlysays
Pembrokeshire
Mercedes C250 Turbodiesel Sport Auto Estate
metallic looking flecks in fuches titan ATF 4134??
I was changing the fluid in my 722.6 today and whilst re-filling the gearbox, from a freshly opened 20ltr tub, I could see tiny metallic looking flecks in the atf going in. I noticed this right towards the end of filling the transmission.
Alarmed, I thought maybe the funnel had somehow got contamined despite meticulous cleaning.
I then opened the Fuches Titan again and tipped a little into the cap and rolled it back and forth in the light and there were the little flecks again...
Any ideas what this is or have I filled my transmission with a dodgy batch of fuches titan with swarf or sand in it?!
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #100
Hi
I've not used it myself, so can't be sure of what it looks like.
I'll need to contact Fuchs about this. Do you have the batch number (should be on the can), when you bought it (order number if possible) and a sample of the oil left over that they can test?
Cheers
Tim
