Answers FArom The Oil Expert Part # 2
charlysays
Pembrokeshire
Mercedes C250 Turbodiesel Sport Auto Estate
I've not used it myself, so can't be sure of what it looks like.
I'll need to contact Fuchs about this. Do you have the batch number (should be on the can), when you bought it (order number if possible) and a sample of the oil left over that they can test?
Cheers
Tim
Hi Tim,
I've still got half the can left so will get the numbers for you tonight. Sample would be no problem.
I bought it about a year ago and it's been stored in my shed the whole time... won't have been frozen or got hot.
Transmission is running fine- I guess the filter would prevent anything nasty getting into places where it could do damage. You'd imagine the filter would be fine enough to stop particles which could interfere with the oil films in the bearings etc seeing that auto gearboxes make a mess in the ATF anyway.
I did wonder if they were tiny air bubbles as I gave it a damned good shaking before using seeing as I've had it a year but I'm not sure.
Will post on here this evening.
CHeers
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #102
If you gave the can a shake, they could well be air bubbles. If you have a look at it again tonight, without shaking it again, hopefully the flecks will have disappeared. If not, send me a sample and I'll send it on to Fuchs.
Cheers
Tim
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
Correct oil for automatic Gearbox - 722.9 - NAG2-FE+ ?
I have a 2011 E Class W212 with the 7 speed auto gearbox. It has stop/start and so has the 722.9 - NAG2-FE+ gearbox (I believe).
I am planning to change the gearbox oil in the near future.
There seems to be 2 oil specifications for the 722.9 gearbox.
I understand that the 236.14 spec oil was correct for the early versions of the 7G NAG2 gearbox but there seems to be a 236.15 spec oil for the NAG2-FE+ gearbox.
I think the 236.15 oil is a blue colour and not miscible with the 236.14 spec.
Do you know which spec oil I should use?
Thanks,
Steve
Here's an off the wall one for you....
I need about 5 litres of hydraulic fluid for the hydraulic drive in a boat. The boat is a Bounty Boats 27 Sedan built back in the 80s and I believe (but can't be sure because the boat is on the French Mediterranean coast) uses a Denison hydraulic pump. Its powered by a Perkins 4108 engine.
The reason I need it is to replace oil lost from a leak - the old fluid looks like Dexron II but its hard to be sure!
Any thoughts what to use and can you please provide a price?
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #105
Thanks,
Steve
Hi Steve
My data lists it as being for up to production number 2834527, it needs the 236.14 fluid, for boxes after that, it needs the 236.15.
236.14 - http://www.opieoils.co.uk/p-68895-fuchs-titan-atf-4134-mercedes-mb-23614.aspx
236.15 - http://www.opieoils.co.uk/p-77986-fuchs-titan-atf-7134-fe-low-viscosity-automatic-gear-oil-atf.aspx
I have no way of telling which on that you have other than the production number.
Cheers
Tim
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #106
I don't have any information listed for that, but I was thinking of a Dexron II fluid straight away, it's what most boats need when it comes to hydraulic oil.
http://www.opieoils.co.uk/c-768-dexron-ii-atf.aspx
Cheers
Tim
steveq
Dublin
Hi Steve
Cheers
Tim
Hi Tim,
Thanks for that.
The production code of the gearbox in my car is 3467420 so the 236.15 spec is the correct oil.
Do you think Opieoils will be stocking that in 1 or 5 litre cans so that I buy 8 or 9 litres for an oil change?
Thanks again,
Steve
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #109
Hi Steve
If they start producing it in smaller sizes, we'll stock it, but at the moment it's only in 20L and 205L.
Regards
Tim
mikeherman
a250/2017/1991
I have a A250 May2017 1991cc . A litre of oil was included in the tool kit. It is marked 229.5 with no SAE style coding. The book just specifies 229.5 without saying SAE code. The online equivalence table list has four columns 0W30, 0W40, 5W30, 5W40 without saying which is best for my car. I have about 3 litres of GALP FORMULA ENERGY 5W40 left over from my old car which is on the list and on the basis that there is not a million miles of difference between an 0W30 and a 5W40 was going to use that when topping up is needed . Do you have a view, comment or advice ?
Susan A Nock
E class 2007 320
I have 2007 e320 CDI automatic it has only done 67k what would you recommend for engine v6, gearbox auto 7 speed, and diff. Thank you for any advice.
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #113
You need an engine oil that meets the Mercedes 229.1, 229.3, 229.31, 229.5 or 229.51 specification, but if it has a diesel particulate filter, you need to use one of the 229.31 or 229.51 oils.
http://www.opieoils.co.uk/c-716-mercedes-engine-oil.aspx
If it doesn't burn much oil, any of the oils that meet those specs are fine, but if it does burn oil, go for one of the 5w-40s.
This is ideal for the gearbox.
https://www.opieoils.co.uk/p-68895-fuchs-titan-atf-4134-mercedes-mb-23614.aspx
And this for the diff.
https://www.opieoils.co.uk/p-982-fuchs-titan-sintopoid-fe-sae-75w-85-fully-synthetic-gear-oil.aspx
You need 8.5L of engine oil, 9L is the full capacity of the gearbox (so probably 6-7L for a change) and 1.1-1.6L for the diff.
Cheers
Tim
As oilman says for the ATF and the diff , they are both what I use . For the engine checkout eBay , you can get 20L of 229.51 MB oil for £53 delivered , which is over 2 oil changes , a lot of forum members use this one
steveq
Dublin
My 2011 W204 C Class C220 CDI has a manual gearbox.
I am planning to change the gearbox oil and would like your advice on the spec of the oil to use.
It is a 6 speed and the gearbox model is 711 653.
Any advice would be great.
Have a look at www.opieoils website , you can put your reg number in to tell you what oil recommendations there are . I don't know anything about manuals I'm afraid
steveq
Dublin
Hi Wighty,
Thanks for that.
I did try the www.opieoils website.
I entered my model, engine, etc. and it seemed to work well to highlight options for the engine oil but not for the gearbox oil. Maybe I am using it incorrectly though.
I only have the Irish reg number to hand -- I will have to look up the previous UK reg when I get home.
Hi Wighty,
Thanks for that.
Just give your local MB dealer a ring and find out
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #119
steveq
Dublin
Thanks for that.
Steve
Tel: 020 8863 9233
