Answers FArom The Oil Expert Part # 2
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
I am always suspicious of oils that just claim to "Meet the specifications of ......".
To me that is just a spurious unsubstantiated claim.
On the basis that it is very difficult and very expensive to disprove the claim, I doubt if any independent authority actually tests the oil.
I know that it is expensive for an oil supplier to get an "Approved by ..." from a car manufacturer but at least the car manufacturer who approved the oil has tested it and is happy that it is used in their engine (or gearbox or whatever).
For that reason I have always stuck with only buying "Approved by...." oils. It does add to the cost somewhat it also adds to the peace of mind.
Just bought one of those 20L Mannol tubs for £45 delivered ...boom !
Gazwould
C250 CDI
I've tried and tested this theory for 8 years .
An oil blender like Tetrosyl will get industry standards basestocks and additive package ingredients from a main oil producer and blend to a set recipe .
You then get a cheaper marketed oil ( supermarket ) that has the same oil performance profile but hasn't the huge costs of approvals , R&D , advertising , sponsorship , etc .
"You can go into any mass retailer (Wal-Mart, Meijer, AutoZone, etc.) and buy a 5W/30 (or any other grade) that will perform well in your engine. One of the best-kept secrets of the oil industry is that these store brands are actually the same, quality oils that are produced by the major oil companies. The only difference between these products and the major company brands is the name on the container and the price. Don’t believe us? Try running your own experiment: do a sample on Oil A after a known number of miles, then do a sample on Oil B and compare the wear levels. You may see a little fluctuation, but it’s very rare for one oil to make a significant difference in an engine’s wear patterns."
www.blackstone-labs.com
Which Oil to Use? | Blackstone Laboratories
"Oil Specifications All modern oils are manufactured to meet certain standardised European/US or vehicle manufacturers specifications, you'll see them listed on the bottles. For example ACEA C3 or VW: 504.00 / 507.00. If a cheaper, non-branded oil carries a VW: 504.00 / 507.00 spec on the bottle then that means it is 100% suitable for use in any car that requires a VW: 504.00 / 507.00 spec. The same goes for a more expensive, branded oil which carries the VW: 504.00 / 507.00 spec. It also is 100% suitable for use in any car that requires that spec. But no more and no less. To achieve a VW: 504.00 / 507.00 spec an oil must be made up of a predetermined set of ingredients (additives) and it is the same set of ingredients regardless of the brand or price point. With both oils your warranty will be intact and your engine will not know the difference between the two."
D'ya Know What Really Grinds My Gears... A Rant About Which Engine Oil Is Best | MicksGarage
www.micksgarage.com
www.micksgarage.com
steveq
Dublin
When I started looking it is surprising what I found.
The UKLA set up the VLS which is the Verification of Lubrication Standards.
It is interesting -- they have actually investigated Mannol.
Gazwould
C250 CDI
They've investigated alot of companies , good that they have .
steveq
Dublin
Yes they have but Mannol is the only one that they state "Product not proven to be compliant following investigation. Escalated to Trading Standards"
Gazwould
C250 CDI
It's not as serious as you think they've just done some overzealous 'marketing' with the manufacturer spec claims .
Now they have gained approval for 504.00 507.00 which is the highest manufacturer spec in the world so it encompasses many other specs but when it comes to the fuel economy it's hard to do both protection and economy as economy is what 20 and 16 grade are all about .
Now I'm familiar with 229.52 aceing the fuel economy further than 504.00 507.00 and wasn't surprised to see it listed alongside as is the case with Mobil 1 5W30 ESP Formula .
But all others
Some of which may be better on economy than 229.52 , it's a big ask .
Trouble is it's a more official point than plastering the packaging with ludicrous bumf , our special QFS formula , extended performance , heavy duty , dynamic fluid technology , dynamic drive , ultimate protection , all climate advanced , new life , high mileage , 3DX , ultimate , superior , crystal power , evolution , super fast , even for the most mundane manufacturer specs .
VLS make the issue of Mannol stating no additive package exists in the world to meet all those manufacturer specs and I agree .
But then to actually mention VW 505.01, why on earth would you worry about it being 505.01 when superior 507.00 and approved superceeded it in 2004 .
steveq
Dublin
They have managed to get on the wrong side of the organisation of their peer group.
That is never a good idea.
Gazwould
C250 CDI
I don't think German Mannol will care too much as VLS is only concerned with UK oil product market .
Probably regard UK as a potholed and Covid infested little island that comes to a halt when it snows .
Well I used the above Blackstone and Mick's Garage information and use Asda supermarket non approved oil , the blender is Tetrosyl in Rochdale who also supply Tesco and Sainsbury's , probably Morrison's
( I'll look on the bottom of container ) and maybe Halfords .
G Force , Carlube Triple R and Euro Car Parts Triple QX.
Used it 'frequently' for 8 years in a 160+K PD engine which the camshaft lobes are extremely vulnerable as narrow .
If this oil wasn't up to spec this would have happened.
And even hole , hydraulic bucket tappets .
Gazwould
C250 CDI
Yes I've seen the Mannol 7715 LongLife 504 507 investigation and what they are going on about is pathetic .
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #153
Last time I looked, I admit sometime ago they were also testing oils and resolving the cases but not naming the brands or oils.
Cheers,
Guy
ssheikh93
London
W213 E220d
Gazwould
C250 CDI
Yes someone had a moan to VLS that all those manufacturer specs was impossible in one oil .
Not impossible to have 507.00 and 229.52 in one expensive potion though .
ssheikh93
London
W213 E220d
Yes I saw the Mobil 1. A bit pricey but will be worth it. Will be purchasing.
