Check codes first. Otherwise you're just guessing.
Good point, well madeHis dash display suggests the right...
Had a look under the drivers seat, think I found the issue. There's a cable there which has been caught and cut. It has two wires inside one is grey and one is green. Next to it is another think black cable. I'm guessing the other is for the seatbelt as the seatbelt still dings if I take my belt of whilst driving.Other common issue is pulling connection when putting seat back and forth, especially if something has found its way under the seat. Without codes though you don't even know which side.
