turbopete
- Feb 4, 2009
- Age
- 48
- Location
- Spennymoor
- 2017 '17' Ford Mondeo 2.0TDCi ST Line X 180 (sorry)
ok, so probably the wrong place to ask BUT at work we have an 04 plate Vauxhall Combo 1.7Di crew van. EML light is on so I read the codes using a little hand held sealey code reader which came up with a code (I forget the number I'm afraid but its a generic to ALL vehicles code) which is explained onscreen as a fault in the 'manifold absolute pressure circuit'
van has over 226k miles on it and is going for MOT Monday as we want to know how much spending it will need to decide whether its worth the money or just replace so my thoughts were, do these have problems with the MAP sensor or its related circuit, that's common and easy to find/cure? or is it likely to have an air flow meter issue (I cant get any live data as our Delphi clone refuses to connect to this van) and if it is an actual MAP sensor, does anyone know where exactly its located? any other ideas/suggestions gratefully received. thanks
