Auto boot open/close fault
dannyfiveforty
Staffordshire
R230 SL500 2003
good morning,
My recently acquired 2008 CL63 has a button on the inside of the bootlid to close it. It dosnt illuminate and dosnt do anything when pressed. I’ve checked all related fuses and are all fine. I have read about a fluid level to check? Any other advise? Things I can do before main dealer?
Stay safe!
Many thanks
drmw
Yorkshire
www.autonomed.co.uk
My last SL had a similar (I presume) system - it too went "off". It turned out that one of the wires between the switch and whatever had broken. I found it, soldered it & it worked for years thereafter. It was on the harness which runs up the bootlid - different on the CL63 but that's all I can suggest.
peterws1957
Lancashire
good morning,
Stay safe!
Many thanks
I would first check to see if you are getting power to the switch. If not as David says it's likely to be a broken wire. The system I think is hydraulic with the pump in the rhs of the boot, presumably the fluid level in that is what you have read about. Should be obvious if it's empty or if there's a leak.
