Auto Transmission Problem on 270 CDi
Mat995
Hi, my 270 CDi does something strange occasionally. A quick depression of the gas pedal sometimes causes the transmission to disengage completely. Instead of changing down it effectively goes into neutral and you are left travelling at speed with the engine revving. Moving the gear selector into neutral and then back into D re-enables the transmission and you then have power again. Any ideas as to the cause of this problem? Has anyone else seen this problem?
panason1c
Somerset, UK
Mercedes ML270CDI, VW Polo 1.9tdi, BMW K1200RS
It is probably the electro hydraulic plate (valve block) inside the transmission causing the problem, this can be replaced with the gearbox in situ.
This is not a common problem, but possibly the plate, a test on STAR may reveal all
we should also remember that worn drive train mountings and worn gear linkage bushes can cause similar shifting into neutral, i would be checking these first.
matt995, is there any obvious slack in the gearchange linkage, felt as a 'clonk' in the hand when moving from P,R,N,D etc?
Evanso
Uk
E CLASS 270 2003 AVANTEGARDE AUTO
I am also having gear change problems with my E 270 w211, its not finishing off gears, i have changed oil and filter but nochange
benz27
Mansfield
C180
Have you had chance to check the gear oil level, thats where i'd start, regards
Have you had chance to check the gear oil level, thats where i'd start, regards (benzservicecentre.co.uk)
Hello young man and welcome
Mercedes-2010
Staffordshire GB
Mercedes C350 AMG Sport (2013)
This sounds very familiar indeed :rolleyes:
http://forums.mercedesclub.org.uk/showthread.php?t=80719
Does this occur when the car is warm in particular? Or, maybe on an incline?
And, if for instace you didn't drop it into N and then D would it regain drive after a few seconds?
You say it's when you accelerate, would you say it's like a prolonged slip between gears as in my thread??
Dave
Mercedes-2010
Staffordshire GB
Gosh I'm 'Tupid!
I've followed the post #7 never noticed the original post date :Oops:
