autobox problem!
rich.g.williams
Cardiff, South Wales
C200 Kompressor Coupe 2003
electro plate 300 pounds - still a rip off if its just a hall effect sensor worth a few quid! apparently the hall effect sensors are moulded into the electro plate?
That was a max fitted price and MB charge much more,,£280 is an average price.
Take the hall sensor built into my struts, a recall free job in the USA but I pay £1000 for a part that has lousy soldering inside and I could have done nothing to have caused the fault
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
  • #44
ok just to give you an update on this derrick wells have had the car today and re-set the fault it now runs fine again and the fault hasn't come back with them doing various tests on it they have said it could be the electro speed plate, but have suggested running it for a while to see if the problem comes back. if it returns i will get the speed plate done , thanks for all the help and advise!, if the problem returns i will be sure to post it on here!
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
  • #46
oh the alfa has gone!! i sold it to a friend on saturday my second car which is soon to be sold is a BMW! although i took that in part-ex plus cash for the alfa. i'll be a one car man again very soon. i wish i had i had more storage for cars!!
be very happy to get back in merc, just driving it to the garage at 30 reminded how much i like the car.
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
  • #47
Well just to update again the merc is back in limp mode so is going in tomorrow for the electro plate work most of you predicted it would be, so hopefully this will sort the problem!
looks like i could be getting a company car in the next 6 weeks so i may have to consider the future of the merc anyway which is a bit sad.
rich.g.williams
derek wells could tell you the fault code that's logged, it only takes one electrical bad contact to a solenoid, one bad contact to the speed sensors or a bad speed sensor to lock the transmission computer and put the car into 2nd gear limp mode
don't loose faith in the car, the fault (although not cheap to fix) is probably trivial in nature - when you consider how the working gearbox can rip up and down through five gears so effortlessly
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
  • #49
i'm not fussed to be honest its not going to be a terrible bill i'm happy in a way that the fault was shown up to be the plate. just a shame that if my role changes at work which looks very likely then i just won't have any need for the car so i'd have to sell.
considering i flew to scotland to drive it back to suffolk would be sad after owning it for such a short period of time
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
  • #50
its back!! now running super smooth, and the auto box was very clean no sludge etc. and the company car now looks off so i should be able to keep it and hopefully get the body work and seat sorted over the next few months :D
Top Cat
Milton Keynes
(97) W202 C230 Elegance Estate
thats a cracking result for you, you get the car fixed up and now get to enjoy the benefits. well done that man :)
kuripot
South Cumbria
2000 CLK430 Cabrio
Similar Problem CLK 430
I have a similar transmission problem on my 2000 w208 clk430 (wdb208) and hoping for some guidance.
Initially the car was intermittently sticking in park but I was able to manually bypass ( with the ball pen inserted behind D drive ) and I replaced the brake switch which I understand to be the usual culprit.
Now in a different scenario the car is stuck in 1st/2nd ? (50mph at around 4000rpm) and requires a restart to go from Drive to Reverse which makes me think it is electrical rather than mechanical. Engaging drive is now clunky but previously was silky smooth.
Oil level using the curtain wire is around 7.0cm at 80 degrees.
To complicate matters I had water in the passenger foot well from a blocked drain but the TCU looks to be dry although I am not discounting this as being at fault.
Also does anyone know of an indie in south Cumbria/North Lancs where I could limp to? I know there is an MB indie in Warrington but that's a 60 mile limp.
Many thanks in advance.
