AutoBox S210.
barch
Salorena, Spain
E290 - S210/1997
Hi All.
Is there any servicing possible on the auto box of a S210? Mine tends to be a little clunky and I just wondered if there was anything that could be done to improve it.
cheers
rpe2
Silchester
Oil and filter change to start with.
Xtractorfan
S class
Oil change as said and if the electronic autobox it can be reset on star to factory default..
B
barch
Salorena, Spain
E290 - S210/1997
Thanks, is resetting likely to help? Is it similar to resetting the ECU?
B
barch
Salorena, Spain
E290 - S210/1997
Look on ECP this evening. The filter looks an easy fit. Not sure how easy it is to fill though. Will have a look tomorrow.
cheers
Xtractorfan
S class
You could try a star reset first ..sometimes a dodgy maf and or low battery voltage can upset these boxes ..so a star reset will show up such faults..
The oil and filter change is always a good idea after 50K miles ..
