Aux battery
bertb1
C220 amp sport 2013
Hello all
Hope everyone is keeping safe
I’ve got a quick question and is probably very easy to answer for all of you but not for me
Car has been parked for 3 weeks so thought id take it for a little drive (32miles)
Stop start and hold not working
I’m not bothered about stop start
My question is if I put the battery on a trickle charger will this also charge the aux battery ?
Can’t see a date on the battery but as merc stickers on it so I’m thinking it’s the original battery
Car is a 63 plate
Thanks in advance
Gazwould
C250 CDI
Main , HOLD has nothing to do with auxiliary.
You are in the fortunate position with a 204 that you can permanently disable Stop Strain by removing the aux battery fuse on top of it or completely remove the auxiliary battery saving 5 Kg .
bertb1
bertb1
C220 amp sport 2013
Thanks gazwould
Sorry for some reason I thought it did
I’ve got it on a trickle charger, I will leave it on for a few hours and see if hold start to work again
onefortheroad
uk.
Thanks gazwould
Do both while its out.
Gazwould
C250 CDI
Boot floor on right will charge up in no time at all being so small .
onefortheroad
uk.
I would but I don’t even know where it is
Using your mobile camera , scan the bar code on drivers door pillar . It'll take you to a mb web site showing you where it is.
As mentioned, its likely to be in the boot .
bertb1
bertb1
C220 amp sport 2013
Yes , found it
In the boot
Thanks all
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
@Gazwould Can you do this on a 2017 W205?
T5R+
Similar issue on wife's car last week.
Took it to work/back 120+miles round trip (critical worker status) - everything working back to normal. Have read in the past that a long run is required.
Gazwould
C250 CDI
I don't think it works without a dash warning on later cars .
