Auxiliary battery location
tayyab
E300 hybrid bluetec
Anyone have an idea of where the auxiliary battery is located on the e300 hybrid 63 plate. I have a feeling it is in the boot with the main battery but not too sure.
Not 100% on this, but have you checked under the filter housing in the main engine compartment?
Steve might see this and confirm or otherwise...
Frankly I wouldn't touch it unless you want to jeopardise your chances of getting it sorted through the Consumer Act 2015. Leave it to the solicitor/dealer to sort out.
If you mess with it the dealer can justifiably claim your tinkering caused the problem.
Steve@Avantgarde
Bristol/Somerset
Thanks, that is just the warning sign that the car has a fault, the fault codes are the download from the cars on board diagnostic system that helps the technicians diagnose whats wrong.
T
tayyab
E300 hybrid bluetec
In regards to the codes, I do remember when the rac mechanic came out the only fault code was gearbox and the code was unknown
