B250E not staying in EL mode. Cold weather
Mercb250e
B250e 2021
My B250e now the weather has changed doesn't stay in EL mode at start up. Does anyone else have this problem?
It will stay in it when set. Just doesn't start in it.
Hello and welcome,
The parameters are not being met to enable the mode you want unfortunately. EV’s and Hybrids are great in the brochure and design lab, not quite so great in reality…
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Battery performance drops when the air temperature drops.
Heating settings is probably triggering the engine to kick in for additional power.
M
Mercb250e
B250e 2021
I know. But I can select the mode I want. Why does it default to a different mode just because of temperature? I've bought a plug in hybrid because I want to use electric as much as possible. Let me choose!
sonic
Staffordshire
Best temp for a EV lithium-ion battery is between 15 & 35C, you cant change science.
M
Mercb250e
B250e 2021
I know I get less miles per KWh but I still want the choice. Why doesn't it allow me to make the decision?
00slk
Cambridgeshire UK
Hello and welcome,
The parameters are not being met to enable the mode you want unfortunately. EV’s and Hybrids are great in the brochure and design lab, not quite so great in reality.
Pretty much answered ;)
M
Mercb250e
B250e 2021
I can run in EV mode. It just doesn't select it by default. If I can run in EV mode when I select it. Why won't it do it by default? It also defaults to hybrid mode when I turn the heating and AC off
00slk
Cambridgeshire UK
Battery voltage could be down?
M
Mercb250e
B250e 2021
It's just software defaults. When we had the very hot weather it defaulted to hybrid. Why can't I choose how I use the car? I want to choose the mode I drive in not Merc.
00slk
Cambridgeshire UK
I think a lot of EV owners are starting to realise that what was tried and tested in ideal factory conditions don't always work in the world of proper temperatures.
I was keen to buy an EV a good number of years back, but having a good automotive back ground and asking all the right questions, I was taken off the list to purchase a new EV. So far everything I asked is never told to the prospective customers. I have a few friends who have gone down the EV or HEV and are finding out capacities, distances and what works and what doesn't when it's supposed to.
This kind of happened with diesel emissions a while back, nothing seems as it should be.
Cold conditions have a huge effect on many things not just electronics.
ajlsl600
france
Why can't the all fangled confusion system just say that on display.?? U know keep the driver informed,. Ie message.. Its too f cold firing up the motor will giv u options as ambient improves... And by the way, some duracells are shixe outside of california
brandwooddixon
Wolverhampton
S63 Coupe 2014
Cars are designed and made by engineers and as such they don't think in the same manner as consumers.
The engineer will think - battery charge is low due to temperature therefore as I must charge it or as its cold we need to heat the cabin quickly, therefore I'll run the engine and boost the warm up time.
It's the same with Start-Stop or ESP, they 'll be thinking we've added these items to the car why would you not want to use them? As such they will default to enabled on every start even if you've selected to turn them off.
