D
dave thomas
hi i have a slk 230 on a 03 plate , i had the bas/esp on i changed the brake s/w, i bought for eurocar parts,no problem for 1k miles now its back on ?what is the problem with this fault on the merc,s i have been told that this switch also provides a 12v supply to a module? does the switch make and brake on both poles ?if it only makes/brake on the brake light side,can i brigde the other side of the poles to see if this will cure the problem? or should i buy a mercedes s/w,regards dave
