Battery usage
jibcl500
Cambridgeshire
CL500,ML55,SLK280
All
If I parked my CL in the garage for weeks at a time, as I do, would it be better to leave it unlocked for that time or alarmed and locked and which option would drain the battery more.
jib
All MB's use less current locked than unlocked its only about 7 - 9 m/a but over time it does add up
brandwooddixon
Wolverhampton
S63 Coupe 2014
If you're really worried about draining the battery then get one of those trickle chargers to keep it topped up. I believe that there's a thread where this has already been discussed.
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Malcolm, what is switched off when the car is locked that saves 7-9 ma?
The alarm/ immobiliser is then in the sleep mode, rather than being active
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Thanks Malcolm, I thought the battery would last better with the alarm active, Ive been leaving the car unlocked which is possibly why it gets through the batteries so quickly.
Miw
Thanks for the link I will take a look at these and decide which is best suited.
jib
www.W140.co.uk&www.r129.co
