Beeping when lights on
Iceberg_UK
New Registration
W203 C220 Avantgarde
Hi All,
I have recently purchased a W203 Estate of 2002 vintage. I changed the battery recently and since then there has been a beep coming from the near side rear storage compartment. No warnings are showing on the dashboard and it only beeps when the lights are on (side / headlights, brake light, indicators). I've checked for bulbs out and there are none although I believe there is a warning on the dash for this. I've checked that nothing is on the seat in case it interferes with sensors for seatbelts and again nothing although again I would expect a light on the dash.
I have a towbar fitted so am about to check the electrics for that.
Any advice would be gratefully received please?
Thanks in advance.
RUBBER_UNDIES
2003 w211 E270 177 BHP
Hi All,
Thanks in advance.
It sounds like to me that it is the buzzer/bypass relay for your tow bar.
RUBBER_UNDIES
Thank you, that's exactly what it was. I took the fuse out and will sort the problem when I have time. Possibly a short in the plug, or other wiring issue?
If it's aftermarket. Just change it. They get moisture In them and shorts the relays out.
