This is up to you now, only you can see the parts in your hands, unless you want to post a picture?
If the arm/pulley is off at an angle it ought to be obvious why, so have a better look and see what gives.
Also, did you notice a washer installed between the arm and the engine front case? There is supposed to be one in there...
I had a belt go ion the M25 doing 70 this summer and got away with it lightly, that was because the tension arm has worked loose and let the belt slide.
Yes there is a washer, just as I was about to start the car after reattaching it I found it in the corner of the bits box, many curse word were uttered.
I took the arm of checked for any play in both the arm bolt bearing and the pulley wheel there was none, the pulley appear to be level with the arm although whether the arm is meant to be in line or not is unknown. The casting didn't have ant creases or cracks in it.
I will try a new arm I guess. Worth a £50 risk I suppose.
I got a new tension arm and pulley for £48, which is a good price.
It was in deed a crossed thread issue. The new tension arm also started to spin up at an odd angle. I managed to force it to go straight aided by a big screw driver. After a few turns it seemed to find the correct thread and started to spin in just using my fingers which was encouraging and then tighten up. How much tread is damaged I have no idea and hope what ever is left does the job.
Welwyn Merx Limited is a family run business with genuine passion, dedication and 25 years of experience dealing with Mercedes-Benz and AMG passenger cars. Tel: 01707 395999www.welwynmerx.uk
