My motor is the 169 horse diesel. Are the AMG discs and pads ok for my model?
Just have your VIN ready when you ring them up that’s all they need to supply you with the correct parts. Oh and yes fit genuine parts as already suggested
+1 with having the Vin# at hand so the correct parts are supplied.
Technically, the B class don't have any model in the AMG range to my knowledge so AMG discs and pads won't be supplied.
That's odd because I found adverts and reviews for B220 AMG line versions.
https://www.autocar.co.uk/car-revie...ercedes-benz-b-220-cdi-amg-line-7g-dct-review
I think you will find that the AMG Line is just cosmetic details and no mechanical improvements.
I favour EBC Redstuff, it's a shame I can't get them for the Viano so 2nd choice is EBC Greenstuff.
Both are better braking than oem and reduced brake dust, red being the better of the two.
I recently fitted EBC Ultimax2 and will be replacing them with Greenstuff next year. I'm not impressed with either their braking character or the dust level.
If your brake pad wear warning isn't illuminated yet the wear sensor will be good for reuse if your careful removing it. I watch for wear and remove it before it gets worn anyway and then programme the pad change for a couple of thousand miles ahead.
If the fluid levels have been topped up during this pads lifetime monitor for the fluid over flowing as you push the pads back into the calipers.
Pump the pedal hard again before the road test.
Thanks. How do you programme the pad change?
