Best of the best oil?
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
If you use opie oils don't forget your 10% mercedes discount
Arudge
Cradley Heath
CLK200 2000 Kompressor
As Ian has already said, the wider the viscocity the better i.e 0w40 is better than 5w40 which in turn is better than 10w30 etc. To put it simply.
My question was more aimed at low weight oils, ie 0w5 and pressure loss rather than viscosity range. Ian did answer and assured me that 40 weight oils thin down more under heat than the fully synthetic lower weight oils. I couldn't use low weight oils in my P38 Range Rover because of the pressure loss, which was largely down to worn main bearings. The camshaft was also shot and also the cam followers obviously. A lot of damage for a lazy V8 with less than 100,000 miles on it.
corradoman
Shell Ultra 5W/40 fully synthetic it is.
As an ex seasoned Ducati owner I know how good Shells reputation is when it comes to oil. 99% of Ducati owners will only put Shell in a Ducati, im not kidding, them bikes are so fussy, anyone that puts anything else in can kiss there bottom end away......
Thanks Ian, i'll treat it to Shell.
When i bought my SLK 350 early this year, the dealer did an oil change on the car, god knows what chippy oil he put in it as it drank it quicker than a park bench alky drank a cheap can of white lightning, i panicked and changed the oil for Shell ultra 5w40 and the car has not used a drop since, i also use this oil in my ford ranger pick up and it loves it and uses non between changes, i swear by the stuff
Sylar
Sylar
Shropshire
C Class/2006/180k
  • #105
Was it a main dealer?
Sylar
Sylar
Shropshire
C Class/2006/180k
  • #106
True but that oil is perhaps even more suitable in British climate than in Oz due to its low cold viscosity. I used 15W/40 Shell Rimula mineral diesel oil for years with great results. It is easy to overkill with oils. The OP did ask for the "best" and I believe that the Shell product mentioned is up there with the best. The biggest benefit with 5W/40, as I see it, is the ability to circulate through your motor very quickly on cold start - the known proven time when 90% of engine
True but that oil is perhaps even more suitable in British climate than in Oz due to its low cold viscosity. I used 15W/40 Shell Rimula mineral diesel oil for years with great results. It is easy to overkill with oils. The OP did ask for the "best" and I believe that the Shell product mentioned is up there with the best. The biggest benefit with 5W/40, as I see it, is the ability to circulate through your motor very quickly on cold start - the known proven time when 90% of engine wear occurs.
Ian.
https://m.ebay.co.uk/itm/300638093968
If i have the right can its not to expensive which is nice.
Was it a Merc dealer who serviced it ?
corradoman
No, just a trader but what looked to be a decent one who sold sports and prestige, but i later found they had took the car to a back street garage for the oil and filter and mot, so i presume they used oil that was not right for the car
Sylar
Sylar
Shropshire
C Class/2006/180k
  • #110
Yeah.... same here, small garage, had the oil in for less than 1000 miles but im pulling it out to be sure.
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
When we bought the CLK recently I was pleased the small dealer allowed a deal where I did the slightly overdue B service myself so I know all the oil and filters are actually done... and proper quality.
Sylar
Sylar
Shropshire
C Class/2006/180k
  • #112
That is MB229.5, you need MB229.3, look at the Castrol on the opie oils link I posted
I take it its ok to use 229.5? It would just exceed the minimum standards, right?
Droverunner
West Cambridgeshire
Any if you buy that Shell on the Ebay link it's made from nice clean gas with no nasty lumps of coal in it.
Sylar
Sylar
Shropshire
C Class/2006/180k
  • #114
Straight answer anyone, can 229.5 be used instead of 229.3? Or is that wrong?
Droverunner
West Cambridgeshire
I think you will appreciate seeing the "horses mouth".
Look at this MB link... http://bevo.mercedes-benz.com/bevolistenmain.php?language_id=1
Open the sheet near the top 223.2 and look for your engine code. Then read off the approved oils.
If I'm right you have a M271 engine then it states oils including 229.3 & 229.5 are OK.
Xtractorfan
S class
Yes to a great extent, but with older cars the modern oils are maybe too thin and will be burnt away as these older engines, with wear and wider tolerences need a thicker oil to seal those looser and higher mileage engines.
There is also a much better cleaning effect with the newer up specced oils so this as well could be the the detriment of older engines, as many of them work well with carbon deposits etc. sealing up the necessary bits n bobs.
Though no reason why you cannot go to 229.5 from 229.3.
Droverunner
West Cambridgeshire
Just having a cruise around the web re the MB oil types and came across something in several forums that I've never heard mentioned.
The main advantage of the 229.5 over the 229.3 is a longer drain life. But... and if true a large but... the extended oil life can only be used if a fleece (polyester I think) oil filter is used not a standard paper one. They say the standard paper one should not go beyond 12,00mls. I see in Google images many genuine MB filters are white rather than yellow of the paper ones... wonder if white are the fleece ones?
Anyone heard this?
Sylar
Sylar
Shropshire
C Class/2006/180k
  • #119
Anyone heard this?
Ive read the same. I believe 229.5 can be used with paper, its just the paper will wear out before the oil.
Droverunner
West Cambridgeshire
Yep seems so. No problem as we will be changing around 10k anyway on the CLK. I've no way of checking but I reckon the ECP Bosch filter I fitted was a yellow paper one. As a matter of interest I have seen a paper filter (the element type like our MBs) on a Peugeot that was left in for almost 30k start to disintegrate so unfiltered oil could pass through.
Tel: 020 8863 9233
