Zarniwoop
- Apr 8, 2022
- 2002 CLK 270 CDI (W209)
Hope this isn't a daft question, but I see from the handbook that there is more than one viscosity of oil suitable for my CLK 270 CDI. I happen to have 10 litres of 5w30 that meets the correct M-B spec, but it's in the back of my mind that maybe after 100k miles I should be using a higher viscosity.
TBH, I'm used to running much older cars than this, and maybe modern engines don't suffer the same levels of wear.
Just wondered what the received wisdom is on this? Should I try the 5w30 and just see if it uses oil? Would there be any risk to the turbo?
By the way, is it true that there is no physical dipstick? Is it possible to add one. I'm sure the sensor is amazing, but I feel you can't really beat seeing the actual oil level sometimes.
Thanks in advance!
Thanks in advance!
