Bi- xenon problem
Stocker
Ashford, Kent
(W215) CL500.... GONE. (W212) E63s
I have a 2001 CL500 and a warning message appeared on the dash this morning, low beam R check lamp,
Sure enough no drivers light, swapped lamps and it works fine in the passenger side,
Would this be a ballast fault ?
Assuming SAM is ok (as both front lamps are protected by an electronic fuse and passenger side still works)
Any input greatly appreciated.
Paul S.
You have the main ECU, then the ballast that includes the bulb holder.
These can be bought on Ebay at fairly good prices.
Lexman8
Yorkshire, The French Alps & Quahog
CL500 (2001): Distronic, Bose, Keyless Go; Honda CR-V EX (2011)
I thought the igniter (with yellow warning) was on the back of the bulb holder and the ballast was underneath the headlamp?
_
Stocker
Stocker
Ashford, Kent
Lexman8
That's what I thought, was going to change just the ballast.
Malcolm, thanks for the info didn't consider another ECU you wouldn't happen to know where I could find part numbers ?
Paul S
bembo449
gainsborough , lincolnshire
every merc ive seen with this problem , its been the ballast at fault , not seen an igniter fail yet , on the w211 the ballast is the same as many other makers , as hella n bosch supply them all so they are not expensive anymore and certainly not a MB only part
