bleeding clutch
pain in the a class
1999 a140 a class took engine out put it back hardest job bleeding the clutch or should that be bleeding clutch...firstly tried the pump the pedal and undo bleed nipple way ....nothing...then emptied the pipe and bled it in a bottle..still nothing...then got a pressure bottle that runs from your tyre...got quarter clutch back... finally stumped so phoned mb they told me the only way they bleed manual a class clutches is by reverse bleeding with a syringe ..tried it one syringe and i got my clutch back...so mb are usefull sometimes ....:D :D
So pleased.you did a great job there. :D :D :D
malcolm
dava
The Toon
Another way with these and all other cars with this type of clutch is to place a pipe onto the front brake caliper nipple, loosen it off and back bleed the clutch ie pressure from the brake system pushes the air out of the clutch, upwards as air wants to travel up and back into the reservoir, works better than syringe.
Thats clever and completely different. :D :D
malcolm
mattkh
England
A160 W168 1999 1.6
I am lost...The pipe onto the front caliper will be full of air.
Where do you connect the other end of the pipe...
What about the seals of the clutch cylinder, how can they allow fluid in the reverse direction
When the clutch pedal is in the up position there is a clear line all the way through to the filling tank, so by pushing the fluid up it will go into the filling tank, its only when the pedal is pressed the the filling hole is blanked.
Malcolm
dava
The Toon
Malcolm
Could not have put it better my self, well done got to the top of the class.
