Bouncing door locks
Status
Not open for further replies.
You can buy the springs on Ebay to repair it £20
dipstick
dunmow,essex,uk
A class
seems to be working ok if the rubber is removed from the metal door card, not sure if the rubber was jamming the rod going up and down, so i,m leaving the door card off and going out and operating it randomly:confused:
There is a rubber grommet where the rod passes through, this can be too tigh causing the problem
dipstick
dunmow,essex,uk
A class
well i,m glad to say the doors back together with the rod rubber removed and all is well,but i have another problem now and i,m not sure if i have made the fault,SRS warning has come up, not sure if it,s come up cos i left the sat nav and a few papers on the passenger seat?
bigtwin
Banned
Bet you a massive £1 you have a connector undone somewhere in the door.
dipstick
dunmow,essex,uk
A class
thought of that and re checked what i had done with door and found no loose connections or plugs, so any ideas or av i got to find someone that can scan system?
bigtwin
Banned
If you can, might be a time saver. This time of year and temp, cracking wires/insulation, plugs etc etc are all a possibility.
53clk240
Earth
W209
Hi television,
I also have this bouncing lock problem and would also really apreciate If you could be so kind and send me the info on how to fix this problem. My email is yenghead@hotmail.com
Thanks in advance for any help sent my way...
adew1953
Hampshire, England
C220 CDi Se auto
Hi there I have the bouncing central locking problem on passenger door on my w203 C220cdi se auto coupe. I have boughty complete door locking mechanism from salvage yard and am ready to fit.
happy to remove door panel etc but it seems from this thread that there is a bit more to it than that.
Any advice documents instructions would be gratefully received.
Also from reading this not sure I have right part?
adew1953@yahoo.co.uk
sidz
United Kingdom
a170/2006/1.7
hi i have the bouncing lock problem on my w169 (2006 a170) with both my rear locks now, any chance some kind soul could send me the info on where to get the kit and instructions etc?:p
thanks
I have sent yours
thanks
I need an address please
danzkix
w203 2003 220 cdi
Hi everyone.
Same problem :neutral:
Television,could you please email me the details for the bouncing lock fix.
Driver's door 2003 W203 CDI 220
danzkix@yahoo.com
adew1953
Hampshire, England
C220 CDi Se auto
Hi television I do not seem to have received anything in my inbox or spam?
I had a go myself last weekend and found that i could not get the lock assembly out, I am guessing that I have to drill the rivets out and remove the supprt bar inside the door frame? but chickened out for reassurance from your post?
What is start of your address which I need to look for so I do not accidently remove under spam.
sorry to be a nuisance
Ade w
I have sent it again to you
Status
