c180 alloys 16" which bolts
akz786
Got some orginal merc 16" (off CLKi think) they are 7j 16h2 ET 37 so should be ok on c180 but i need bolts questions is which ones? i see these 60mm ones which have a long neck and thread about 25mm approx are these correct?
TIA
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
ask a mercedes dealer,
the alloys on my c220 (1995) use different bolts to the winter wheels, and sorry i don't know the measurements
cheers
anyweb
A
akz786
cheers
anyweb
Thanks I shall do that. Im sure they can cross reference the alloy part number to the wheel bolt part numbers.
type49
IF they are genuine MB wheels, then CLK208, C class202, E class210, A class168 & SLK170 all have the same ALLOY wheel bolts but you cannot use steel bolts on alloy wheels.
A
akz786
Yes they are genuine MB wheels, I have seen some genuine MB alloy wheel bolts - 60mm length with a long neck and thread maybe 25mm or more so seems these are the ones I need. In any case i need to clean the alloys and get the part number off the inside then maybe ask MB
