Andrew Galbraith
- Jul 23, 2018
- C200 2004 1.8 Petrol
Hello to the budding diagnostic gurus,
I have been a happy mercedes owner for 20+ years and owned various CLKs and C-class.
A month or so ago i had a window washer fault and had no wipers or fluid. After looking at the replacement options I opted for a replacement unit, like for like, from Lithuania for £21.
After fitting, everything seemed to be fine but the right indicator was stuck on so stripped the indicator stalk out again and when it was all back together nothing now works.
Both key fobs now fail to lock/unlock the car on both RF or IR. (Both tested and working fine)
Both keys fail to turn in the ignition. (EIS unit sent to repair centre who tested both keys and all good).
At this point I had been through the multitude of MB forums to see if this is a common problem.
It looked like the steering lock could play a part in this (would the keys stop their remote locking function due to steering lock..seems really dubious.)
Anyho, stripped out the steering column and removed the steering lock pin and bought a £30 emulator to see if thar would help resolve, alas, no dice.
I am now stuck with a car that I cannot move (stuck in Park and cant turn ignition to release) and local fixer has offered to supply 2nd hand steering lock programmed to car for £400. I am in serious doubt that this will fix the issue I have.
I have checked all the fuses, removed and re-seated.
I have checked the battery, 12.4v constant.
I have been through the forums and done all the suggested things like disconnecting battery for 3 hours and using the metal key in the boot lock.
I would really appreciate any guidance as this is now starting to drive me up the wall.
Andy.
Andy.
