C200 aircon fan problems
ventech
My blower stooped working so I removed it and applied power directly to the terminals & it is OK. I assumed that the electronic module is faulty, but it could be the switch contacts on the rotary fan speed switch. I intended to replace the module £120 from dealer, but it could be the switch is faulty not the module.
The heater/aircon blower is different in aircon equipped cars. There is an electronic module bolted to the casting that is not present on the non aircon blower. This is connected to a 4 pin plug. Two wires are heavy, probably 2.5 sq1 mm, and the other two are very thin. The rotary switch has 5 posn, so presumably it has resistor or some elements on it to produce a variable voltage to the electronics module. I have tried measuring the resistance between the two thin wires two each other & to ground in each position & found no difference in any position. This suggests that the contacts are open circuit.
Can anyone expand on this & suggest further tests? It should be possible to test the module in situ by connected the control pins to a pot connected betyween +12V & ground.
On the rear of the control unit, pin 7( that is if pin 12 is ground) should have a voltage of between 0 to 5.6 volt, this voltage goes to pin 2 of the fan regulator pack.
Do not forget that there is a fuse for the fan motor in F1 that gives 12 volts to pin 3 of the regulator.
The control units hardly ever break down, the switches and dials and press buttons all clean well with a good switch cleaner.
Do check the length of the carbon brushes, as just by moving it could let it start, and this may be the only problem
www.ckinsurance.co.uk
