C215 CL500 rear seats removal
CL500215
New Registration
2004 CL500
Hello everyone, does anyone know how to remove the rear backrest seat/ arm rest on C215 CL? Thanks in advance
peterws1957
Lancashire
If it's anything like the 216 you need to remove the seat bases first. Pull up at the rear and feel underneath at the front for the bracket and push the clip in and pull the seat upwards. This enables you to access the centre console fixings on each side. Use a plastic trim tool to gently pull out the sides on the console to release from the plastic fixings (don't try to press these they will break) and then pull the console upwards from it's short track. The seat back will have bolts on each side - undo these and lift upwards from the top track. 10 minute job if you've done it before!
