oigle
- Mar 15, 2005
- Age
- 83
- Location
- Redcliffe, Queensland, Australia
- Website
- members.optusnet.com.au
- 2003 ML270 sold but not forgotten. 2022 Kia EV6 RWD LR
A good idea, but seemingly it is not available as a seperate part, or rather, no one has been able to find a part number for it (including the guys at MB).
Yes, that was the issue - no availability. Wonder if I should look at a tap in the hose, manually operated. Would be a bit more professional. I could put it in place of the thermo and just open it when I felt the situation warranted - towing etc. Sqeezing the hose would work but damage to the hose would be possible/probable in the long run. Bit agricultural too.
Wonder if there is a suitable in line thermostat available from another usage or make? Might be worth a bit of investigation. Seems this issue could be quite widespread.
Alex, do you see ANY issues with taking the low temp rad out of the system for normal usage? The heat exchanger still operates exactly the same as I understand it except that the water at the exchanger will be some degrees warmer. This could result in the auto tranny fluid working at a higher temp, but presumably still at an very acceptable level during normal load usage. I see this unit (low temp rad) being there because MB in their wisdom have approved the ML for towing up to 3500kg, which is quite high and would put enormous heat loads onto the auto tranny. Is that as you see it? Trying to be careful here!!!!
