C230 1997 Auto Sport Sluggish when starts and started to backfire!
ds24215605
Lancashire
Mercedes C-230 Sport Auto
When i start up after a few hours parking the engine struggles to keep constant revs This goes away after a short time yet now the car has started to misfire / backfire when i depress the accelerator pedal quickly? It still goes ok on motorway but is getting sluggish as time goes on. I have just had a service - new plugs filters etc but no change?
Any ides anyone, could this be the MAF?
Derek
It could be, try unplugging it to see some will go well to prove the point
ds24215605
ds24215605
Lancashire
Just to check is it easy to do? tools reqd?
No tools just squeeze the catch and pull the plug out and try it
ds24215605
ds24215605
Lancashire
Bravo, it seems to be ok, i will test it later today after it has stood a while. Any tips on cleaning?
ds24215605
ds24215605
Lancashire
Removed electric connection, running fine. How long can i run it with it off before it does any harm? I work away from home (forces) and commute 200 miles to get home would it be ok to leave off for the journey?
I have now removed the MAF but it looks to be clean inside; when i run my finger inside a little bit of black deposit appears but nothing much.
Would this make much differance or could it be the electrical connection at fault?
Derek
Derek
It needs a new one, just worn out, the cheapest place is any Bosch service center, if there is a part number on the actual element in the tube then you can buy this and £100 cheaper.
ECP do some,,ask them.
Do not buy from Ebay.
It will do no harm without it,,,it may be rather thirsty
ds24215605
ds24215605
Lancashire
Do you mean the electric plug or the MAF actual cylinder?
The number on the MAF is;
Bosch
0 280 217 114
or
000 094 09 48
Derek
ds24215605
ds24215605
Lancashire
Had a look on net would you use genuine Bosch parts? ECP have 2 for sale, one for £80 and the other £155, both look the same. I presume one is a copy? What would you recommend.
If the actual sensor in the tube has a Bosch number the worth asking Bosch, I would imagine that both by ECP should be OK and not the rubbish on Ebay
ds24215605
ds24215605
Lancashire
Many thanks,
i`m gonna go for the original Bosch to be on the safe side. I will let you know later how it goes.
ds24215605
ds24215605
Lancashire
Bought new MAF (Bosch) fitted in 2 mins, running like a dream, if i had owned the car from new i would expect this is how it would have performed, absolutely brill.
Many thanks TELEVISION for your priceless advice which has prob saved me a small fortune, and Parrot of Doom for his excellent pictures.
A happy Merc Owner.
