c270 cdi power steering noise
housewinnie
hi out there and i thank you all in advance of any replies and help....
i kepp on getting an intermittent noise or groan from the steering it usually happens when i turn the steering at slow speeds or standstill and then it goes away..is it possible to check the fluid level and if so where is it...or is it something more sinister,or maybe this is normal...
i cant believe something else has gone wrong already spent £2500 on it in last 6 months...new turbo.alternator clutch etc ,etc and of course a service...all sympathy welcome...wish i had never bought the car....
cheers again in advance
Sorry to hear of your woes. Its normal on full lock for the steering to groan when parking
H
housewinnie
cheers but it doesnt always just happen on full lock
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
I used to get something similar on mine, sometimes like a whirring noise, not necessarily at full lock. Reported it to Merc at service but they said they couldnt find anything wrong, so keep an eye on it . What? I said, if you cant tell me what it is how can I keep an eye on it?
Couple of days later I looked at reservoir and it needed top up, which solved problem. Thing is, at the time the car (01 C180) had only done about 30,000 miles, no leaks anywhere, so I guess it must have evaporated, or something like that:confused::confused:.
star
Reading
Smart + others :)
does it do it mainly when cold, if so check pas oil under cover, it maybe slightly low and when the oil expands its ok.
H
housewinnie
can someone please tell me where the pas fluid reservoir is on my 270 cdi ?cheers
star
Reading
Smart + others :)
under the right n/s part of the engine cover, need to undo a few torx bolts.
