C32 2002 induction kit
Looking for a 4" induction kit
  • Anyone
    Votes: 0 0.0%
  • Anyone
    Votes: 0 0.0%
  • Total voters
Brusk
C Class 2002 203 c32 amg
Hi there everyone my name is brusk I'm from the UK. I have just bought a c32 any 2002 as my first performance Car. Im an apprentice at Mercedes as a mechanic.
Been looking for an induction kit for my car with a 4" kit I'm strugging to find the right place and where.
Any help would be appreciated.
Thanks Brusk Tuncel
Hi
Save your cash ;) Fancy induction kits just make more noise ..... if they added bhp, then the manufacturer would have fitted them as factory fit :)
Uncle Benz
West Sussex
Mainly Mercedes
The most restrictive part is the y piece that goes from each air filter to the throttle body. If you take it off you will see what I mean. I fitted the y piece from a 55 Kompressor engine to mine and it made a significant improvement, although I did have it remapped by DMS beforehand. I did have SL55 air boxes on it, but they don't fit very well and made no further improvement on the dyno so I went back to the original boxes but kept the better y piece. You will need to fettle the scuttle plastic slightly to get it in. Mine made 404 on the dyno, but that was about thirteen years ago now. Still feels nippy, but the world has moved on!
B
Brusk
Thank you for you feed back, so
If I get the y piece of the 55 I will need to just fiddle around with the original box to fit the y piece?
Brusk
Uncle Benz
West Sussex
Mainly Mercedes
You need a couple of thin rubber sleeves over the original airbox outlets - the 55 rubber pipes are very slightly bigger internal diameter. I think I used a couple of bits off a wheelbarrow inner tube. How's that for a memory!
B
Brusk
Great will give it a go. What about exhaust manifolds? Worth it? And pully kit?
Karren Stanly
S Class
Absolutely, a new one obviously ended up with adding more noise and making it worse.
