Whilst i fully agree that Hydrographics are the better option for ease and finish. I carbon wrapped the grile and foglight surrounds myself on my Octavia and that was still perfect the day I sold it nearly two years later. That's not because I'm some uber wrapping genius, far from it. It was more that I am CDO, used decent stuff (3M in my case) and took my time to ensure it wouldn't peel.
A sheet of 3M wrap big enough to do a grille quite cheap (circa £20-30). No idea how much Hydrographics would be.
Iain, if you are going to do this yourself then some tips.
- Remove the grille from the car to ensure you can get access to all the areas easily
- Use a hairdryer to heat up the wrap to allow you to get it into all the nooks and crannies. However be careful not to stretch it too much otherwise it won't stick.
- Unless you intend to remove the wrap then be sure to 'key' the surface with some 2000 grit sandpaper, rinse it off and wipe down with IPA. I managed to get a spare grille extremely cheap off eBay (£20 vs the near £180 direct from Skoda - Mercedes are even more expensive)
- Take your time doing it and learn how to 'overlap and slice' to join seams. Watch this video that explains it. It makes the finish a LOT neater and helps stop it peeling.
They have Knifeless cutting tape now but no idea how much it is.
This one is also worth a watch.
If you're paying someone to do it then ignore the above!
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
