dieseljock
Hello all,
This is my first time posting on the forum, but I have been pulling bits and bobs from it for some and have found some seriously useful threads from other members regarding the typical problems caused by the EGR system on the 320cdi's. mine has done 135k miles and runs well, but smokes considerably on acceleration under load in the higher gears. I've had a wee poke around and have noticed that the connecting rod from the actuating motor to the swirl flap pivots has come off, and there is no movement possible in the swirl flap mechanisms. I am working under the assumption that the EGR has nicely gummed up the flaps along with everything else in the inlet manifold, and I'm planning to remove it and clean it up along with the EGR pipework. I'm also going to install the shunt posted by Dieselman to stop the EGR doing the same again. My question is this- Has anyone tried simply removing the swirl flaps? What would be the result? I'm anticipating that they're going to be pretty messy/seized, and I know that people with bmw diesels commonly do away with theirs to avoid engine damage when they fall off and get sucked into the engine..They tend to report either improved performance/economy(if the flaps were jammed shut I guess) or no loss of performance and economy and more peace of mind! Would taking them out cause an engine management fault code or reduced fuel economy? I'm assuming there must be a reason as people have posted about getting new manifolds when they snap one off trying to clean it. Any advice would be most welcome before i tackle the wee buggers!
