TechnoWhizz
- Mar 18, 2016
- Location
- Rugby
- ML500 W163 2003 Black LPG
Hi All,
2003 W163 ML500 mixfuel. Problem is the car heater isn't working. Fan works, flaps seem to work but mainly cold air, never warm/hot.
Been to Mercland specialists in Nuneaton, Fan and regulator fine, Matrix fine, Hot/Cold valve moving, auxiliary pump replaced (!), Coolant clean and replaced. Engine reaches 80c fine, and doesn't overheat. No loss of coolant.
No improvement.
Runs on LPG (mostly) fine and switches from Petrol->LPG fairly quickly. Only thing is on full acceleration from start, LPG system can't cope and has to be on petrol. Also MPG is about 13
Blame is being laid on LPG system and it's use of the coolant system to heat the LPG fuel, but as they aren't LPG trained they can't touch it.
Tried to speak to the original installer for LPG type so I can get it serviced / checked, but not yet forthcoming.
Any ideas to save me from freezing my bits off? I feel (hope) it's something stupidly simple that's been overlooked......
Cheers Chris
No improvement.
Cheers Chris
