Rizwan.arif
- Sep 21, 2015
- E220/2008/2.2
Hi I own a 2008 Mercedes E220. I have couple of issues with it which needs some of your guidance to helpe sort out
1.Since last October I started having problem while turning to the right only. When I turn right at round about or at bends at fair speed(not really fast just normal speed) I hear some grinding noise coming from pessenger side front wheel and it only happens occasionly not on every turn unlike CV joint problem. And also sometime when its slippery or turning over a metal (main hole covers) the car will suddenly turn to right. You feel it like suddenly wheel had more turn to the right. And this only happens when turning to right. Left turning is all fine. Now I have took the car to Mercedes and they did not find any visible problem or wear and tear to linkages or bushes or any other steering parts. Also I had the MOT done on my car and it passed right away. Infact I asked the guy at MOT station too if there was anything wrong with wheels or steering parts like play or anything else and he said all is fine and in good working order. Now what I have so far established is that there is problem on the near side(pessenger side front wheel) which is causing this problem. But i am not sure what is the cause. My wild guess is, it could be the wheel bearing but cannot be sure about it. So any advise would be appreciated.
2. While accelerating from 25mph to 35mph sometimes I feel the car is jerking. But it goes away while 35mph speed is achieved. It happens quite often. I have checked few forums where they advised it could b low fuel in the transmission box. Any ideas.
Thank you for your time
Sent from my SM-N950F using Tapatalk
