CLK 200 Kompressor Rear Passenger Headrest Back-Cover broken off. Replacements?
Scott275
CLK 200 Kompressor / 2004 / 1796c
Hi there,
My car has leather headrests with abs plastic covers. I've noticed one of them has snapped in multiple locations and now hangs loose on the poles.
The part does have a code to identify it, but after searching on Google or other threads I haven't found any place to buy spares from.
The code is 10 45 774 GWA
Do you know where I can get a replacement of this?
Many thanks.
AnthonyUK
Alton, Hants
C240 estate 2002
I had a similar issue and couldn’t find one so super glued it back on.
peterws1957
Lancashire
Hi there,
Many thanks.
You've tried an MB dealer? The code you quote is likely to be the colour code. The actual part number will start A 208 …….. If you go on the website 7zap Mercedes you can track the actual part number down. Once you've got the right model, go onto the sub section Rear Seat.
Scott275
Thanks for the recommendation for 7zap, looks promising for finding the part! I'll so some searching for the correct part.
Unfortunately, while I can superglue some of it back together, there are parts of the cover missing. So a replacement would be better suited.
