clk 320 cdi Crackshaft position sensor
ells_924
Gloucester
clk 320 cdi
anyone know the cost of getting the the above done at a specialist?
code 0335 just come up after a very larboard start..
AMGeed
Poole, Dorset
S204 C180K
Mine cost just under £200 for the part and labour two years ago if that's any help. An indy did the work.
Have you got the "difficult to start when hot" symptom.?
An indy with STAR can confirm if your CPS is faulty.
E
ells_924
Gloucester
clk 320 cdi
yea that ok, just wanted a rom before phoning this one in!
dam cars cosing me a mint a the moment
Stability
Mercedes
CPS are really common on diesels but very common on v6 v8 Petrol.
This fault will flag sometimes if it’s turning over but not firing.
Check the fuel flow in the transparent pipes from fuel filter
DanB
West Midlands
CLS320 CDI
I know you haven't asked and I don't know your mechanical skills but this is a job you could tackle yourself.
The sensors are less than £50 from Mercedes and have just a single electrical connector and a single allen bolt holding it in. The biggest problems is access but with patience it could be a diy fix.
E
ells_924
Gloucester
clk 320 cdi
hi guys, well the the code has cleared now so seems a strange one.
I may order the sensor and have a look at trying it over the weekend.
thanks
E
E
ells_924
Gloucester
clk 320 cdi
just ordered the part 26£ inc vat at the local dealer!
Stability
Mercedes
I meant to say ‘ not really common
DanB
West Midlands
CLS320 CDI
Result. I'm finding the Mercedes dealers are very competitively priced for most things. Especially if they give you a little discount on top. Very impressed.
I got a set of genuine Mercedes branded Bosch wipers for £30 delivered - ECP wanted £50 for the same part without Mercedes badges. The genuine oil filter was cheaper than every other oil filter at ECP (Bosch, Mann, etc) bar the cheapest Crossland one.
Good luck with the swap mate.
