CLK W209 Glovebox won't stay shut
Marcel-Anthony
Newcastle
C350 Amg Sport Coupe, ML300, Slk 200k
Hi Just watched your vid. I had this issue a couple of weeks ago and I could not find nothing on this so good for you for posting it. If you actually undo the screw underneath and bring the catch forward and re tighten it should cure this for you and be a permanent fix. I guess each car is different but it worked for me.
I got the advice from forum member in the end.
Alex Crow
Super Suffolk
The advice about adjusting the catch is all here in this thread, somewhere.
The problem is there is too much to read!
A miracle fix for the broken catch in the lid is what most are looking for...
raj1983
New Registration
london
clk2005270
Can someone send this to me
my catch does not seem to lock in the glove compartment - can someone help without me spending 250 quid on a new one
If it is not broken, then adjust,, if broken then no miracle fix other that suing mercedes.
I am surprised that no one has come up with a mod for this.
Tenyamman
Registered
Lincoln
2006 clk 220cdi sport
Could I also be sent the instructions please Malcolm. Have the w209. Cheers
I am so sorry, my files got lost when I moved house. Are there some Utubes out there for this now, there should be.
SteveX
lol 24 pages and all you need to do is remove the CD changer with one screw, and loosen the centre torx screw in the roof to adjust the lock plate out :D
Over time when shutting it just moves it back, it's one screw to adjust it outward, 5 min job lol.
PS I know this is an old thread, just adding this comment in case anyone searches and finds a 24 page thread with no answer to a simple job :)
Many can fix their own by adjusting with care, a poor idea though.
yinujim
Essex
92' 500SL, 04' E500 Estate
I need a new Latch which means £150 for a used glove box:eek:
Can the latch be removed and swapped over to the old lid?
rf065
Grossbritannien
The glovebox fix takes a few seconds with a screwdriver, it really is that simple, just take a look at the lock, loosen the screw, adjust & retighten. There really is no need to watch videos of the procedure, it really is that simple!
Sparky Mark
Registered
CLK 220 2008 2.1 CDI
Hi guys, anyone know if you can purchase a replacement glovebox lock mechanism separately? Mine has obviously been slammed one to many times. Anyone ever replaced one? Thanks for any info. It’s on a 2008 CLK
