Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
just checking what tools are needed
1. The Torx bolt on the front disc, is this a T30? It fits but seems a bit loose. My other choices are T25 or T40
T 40 is too big. T25 goes in very sloppy wont rotate light finger , but so loose if you applied a wrench it would definitely rip thenstar shape round. My set doesnt have a T35??? But goes up in 5s otherwise.
2. What size socket is needed for The brake Calliper to the Steering Knuckle?, its an M14 bolt. I this assumed a 22mm socket ... wrong.. thats too big.
19mm is too small, and I dont have a 20 or 21 mm socket.
So which to buy?
I do have a 1/2 inch drive M14 Spark plug spanner that seems a snug enough fit. Are they 20 or 21 mm sockets .. will that do? I ask as its done up to 160Nm so get it wrong and you bet it will round off!
3. Is the Brake Sensor bracket Bolt an E10 socket? It seems to fit, just a tad loose. And you guessed it I have a set with E11, E10, E8, E7 etc but no E9!
Before you have a winge .. I am trying to be brave, just cautiously trying to avoid screwing up.
I assume all these bolts are usual and not reverse threads LOL ?
So which to buy?
