Cranking wont stop even after I take FOB out!?
vdimov74
A 200 CDI/2005/Diesel
Hello everyone, I had my car recently to mechanic and they worked on alternator changed some parts, took the car few hours later all looked good, but
next morning when I tried to start the car it was cranking and did not start at first but I turned the key fob to 0 and it was still cranking then I removed the key
and it continued to crank like 2-3 minutes.
Can anyone please advice me what could the cause be since the car all worked perfectly fine until they worked on alternator.
The reason I sent car to mechanic was because in the morning when I tried to start it it was squeaking really loud.
Please if any expert have had anything like this worked on to tell me what could it be.
Model: Mercedes A 200 CDI 2005 W169
Thank you in advance.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Take it back to the mechanic who worked on it.
V
vdimov74
do you think they made something and if it should be covered by what I paid already since this issue came only after they touched it?
ajlsl600
france
I would think a relay is stuck or sticking in the closed position??
V
vdimov74
Here is an update was about to go to mechanic turned the car on started without problem I realised forgot my wallet turned the car off and it started cranking. It took a while to remove the battery to stop it and it was making strange sound when I put the battery back and it wont start now. The video shows the sound I was hearing.
V
vdimov74
Is "the mechanic" an MB specialist? If not, I think you need one.
Others on here will advise better than I.
RayH
Thank you Ray, I don't think they are. I had this car for 3 years and no issues at all until I took it to them for glow plugs light and all started going bad since then. They were saying today its something inside where the key goes, but I saw a lot of videos and all points that starter is blown since there is no power anymore I can't even put my key fob inside. I will have it towed in the morning to official MB service.
I'm tired of paying them so much money and it's still not working as it should, I would rather now pay full price from what MB asks I'm sure it will be less then what I paid them over this two months.
Best Regards,
Vasko D.
rayhennig
1991 300CE-24 Sportline
Where are you located? Tell us and someone on here will recommend the right place to take your car. And that will probably NOT be an MB main dealer.
I can't comment as I'm in France.
Others?
RayH
