Creaking noises from both front doors
eurkhan
Aylesbury, Bucks, UK
C220/2015/Deisel
I am a first time owner of a Mercedes C220 Diesel Sport 2015. I have had the car since end of June and have 5k miles on the clock. After only a few weeks in I began to notice a slight creaking noise coming from the driver's door top edge. The noise was as if the glass of the window was rubbing against the rubber seal of the door. It was only noticeable on very rough or uneven road surfaces. Since a few weeks ago the noise has got more consistent and has also started on the passenger side front door and is much more prevalent. To add to this a crack appeared in the bottom right corner of the windscreen a few weeks ago too. This crack has now spread the half way across the bottom of the windscreen. There appears to be absolutely no evidence of a stone chip nor do I recall anything striking the screen whilst driving. I am the only driver of the vehicle.
Could the creaking noise be linked to the cracking windscreen? Why is there creaking of the windows/seals? Incidentally the noise disappears when you lower the window by a centimetre or so, i.e. when it is not touching the seal.
Is this normal, I would expect better quality and workmanship from Mercedes.
Pookis Dad
Inverness, Highlands, Scotland
2000 Range Rover V8 (miss the Benz)
You could try some silicone spray, sprayed onto a rag and rubbed over the seal to lubricate against the rubbing.
There doesn't have to be a chip visible for a crack to appear, a small stone flung up by a truck could have weakened it and the next pot hole would have put enough strain.
Believe it or not, the screen is an integral part of the strength of a monocoque body. The glue allows a tiny bit of flex, which is why a small crack will turn into a large crack pretty quickly as the screen strength is lost and the bodywork flexes.
E
eurkhan
C220/2015/Deisel
Thank you Pookis Dad.
I will try the the silicon based spray. My concern though is getting a film of silicon on my windows.
Kind regards,
Ehsan
Pookis Dad
If you spray a tiny amount onto the rag and use one finger to rub it onto the rubber you should be fine.
I use silicone spray on my window runners to lubricate them and prevent the motors straining to push/pull the glass.
Plenty products to remove it if you apply too much ;)
nyx
worthing
w210 1998 e240 saloon
as above, siiilicon spary is great. i put some on my window rubbers and they now go up at least twice as quick as before and silently.
sweetmandavid
New Registration
Portsmouth
C220 2015
Good morning. I have the same car and the same age with the exact same issue. Did you manage to resolve the really irritating noise?
David
Andy.M
Rochester Kent
2014 GLA250 Premium Plus, Night, AMG Exclusive Leather, Driving Assistance Packs COMAND DAB HK Audio
A 2015 car shouldnt need lubing yet !!!
PovertySpec
Hampshire
E220 CDi 07/57
C220 Diesel Sport 2015 .. 5k miles on the clock .. creaking noise coming from the driver's door top edge .. a crack appeared in the bottom right corner of the windscreen .. crack has now spread the half way across the bottom of the windscreen ..
Sounds serious. Body flex? Misaligned screen? Missing adhesive on the screen?
I doubt rubbing silicone grease on it will work. Much in the same way rubbing a brass lamp won't produce a genie.
Take it back to the supplying dealer.
uisd
Stewarton
(15) C220d AMG Line
C220d AMG Line 2,500mls - I have exactly the same problem, a very annoying creaking/cracking coming from drivers door. Car has been with the dealer 3 times where they have tried a "temporary fix" as instructed by Mercedes. The temp repair has reduced the noise slightly but it is still obvious. The dealer says Mercedes are looking into a permanent fix but they have no news on timescale; ie a recall for door seals.
Very disappointing and not what i expect from Mercedes.
uisd
Stewarton
(15) C220d AMG Line
Further to my previous post, as Mercedes could not provide a permanent fix for the noisy door, I complained to the dealership and they have replaced my car with a new one!
The dealership have acknowledged that there is a known fault with the door seals but no solution has been found at present.
Frontstep
T210 320cdi
I wonder what they will do with your old one ?
Is there a compound full of creaky cars somewhere ?
uisd
Stewarton
(15) C220d AMG Line
I wonder... the dealership did acknowledge that one of their own cars has the same problem....
